[LightBoost Alternatives?] Replacing this terrible gn246hl help!
Posted: 12 May 2020, 10:01
(Very long winded and i'm also a monitor newbie so sorry in advance but any help is appreciated)
I just completed a new system and have had my first experience running a high refresh rate with a 144hz Acer gn246hl for a few weeks now and i'm horribly disappointed with the display results where my old 60hz monitor was better. I play a few shooters (CSgo, TF2) and a few empire building games with alot of screen scrolling. My system has a ryzen 3600x and a 2060 with the intent of running 1920x1080 at 144hz smoothly. When i first got the system up and running @ 144hz I noticed that although it was high refresh and much smoother than my old 60fps rig, when strafing in shooters or scrolling in my empire games I saw horrible ghosting and just blurriness in general and bad picture quality at 144hz along with what i believe to be overdrive issues if I understand them as they are explained on this site. I've been reading the forums and guides here for literally 12 hours now to improve it. Upon researching it a few days ago I came across the "enable lightboost" help area and did that to where lightboost is enabled on 100hz and 120hz (and shows a green light on the monitor instead of the blue so it is working). The blurriness is dramatically improved although using the full screen strobe crosstalk Test https://www.testufo.com/crosstalk showed the top of the screen is still ghosting and a slight amount on the bottom which others have reported but still better than without lightboost. In my games when i scroll with the keyboard right and left or strafe in the shooter, text and other items in the same top areas showing the crosstalk are ghosted compared the the middle of the screen identical to the strobe crosstalk test. All games do it but one game in particular with alot of text on the top of the screen just looks ghosted when scrolling and it is very noticable. This is the first thing I want to try and remedy and hearing that my gn246hl is a pretty bad 144hz monitor, I am hoping that you forum members who are MUCH more knowledgeable can help me choose or direct me towards a monitor that will really make games look like they have smooth visual framerates regardless if the game is outputting 100hz or higher like 144/240
Now here is where my limited knowledge needs your help and i hope i explain this properly........
The quality of the games when they are stable at 120hz/fps is awesome with the strobe crosstalk screen blurring on the top of the screen being ignored for now. Some games (not all) though at several times during heavy action will drop down to around 95 frames and i get pretty bad stuttering worse than what i believe 95 frames should look like. I used the CRU app to make a custom resolution for 95hz to test (no lightboost) and when i play these games that normally struggle to maintain 120 frames and run instead at 95hz it's smooth with no noticeable stutter framewise. So getting 95 frames @ 95hz is smooth but 95 frames @ 120hz looks horrible. Again to my understanding from this site that anytime frames are lower than the refresh rate it will stutter and i believe from reading here that this is what g sync and freesync were meant to address. I love the smoothness of higher refresh rates/frames but with some games dropping below the monitors refresh rate and stuttering, i take it that I need to look into a gsync or gsync compatible freesync monitor to ensure that it is smooth when it dips lower right?
My only experience with refresh rates higher than 60hz has been in the last few weeks with this awful gn246hl so I have no knowledge of other monitors abilities and picture quality. Ultimately I want a monitor that will be smooth regardless if my system is producing 100 frames or higher FPS. Now I think I understand that variable refresh rate tech cannot be run at the same time with any blur reducing tech like lightboost, ULMB or other monitor manufacturers versions of it. Since the main thing i'm looking for it smooth visual framerates I guess I won't be using motion blur reducing tech on any prospective monitor but I still want it to have low blur. What monitor should I try looking at that has gsync/gsync compatible freesync (running a nvidia card) but has decently low blur without employing motion blur tech? My last question is should I look at a gsync'd 240hz monitor instead of a 144hz? If i have a game that again runs @ 95 frames without the motion blur tech on, would it look better on a 144hz or 240hz panel both having gsync?
How is the 240hz ViewSonic ELITE XG270 when run with the pure xp OFF and gsync ON in regards to blur? If this monitor isn't recommended for what i'm looking for it to produce, which other 24-27 inch monitors with 144hz or even 240hz @ 1920*1080 with gsync would be recommended? I would like to think that there must be monitors out there that look better without motion blur reducing tech being used than this junk gn246hl with its garbage lightboost on.
I know this is long and I rambled but please help me.
