Setup:
- Monitor: BenQ EW3270u
- Resolution: 4K, 60Hz
- Display mode: borderless windowed for gaming
- Display interface: DP 1.4
- GPU: RTX 2080Ti
- G-SYNC: On via NCP (monitor compatible, even though it's a FreeSync)
- Dual screen: Yes, Dell U3415W
Also, if I put a 30FPS limit, issue seems also to disappear (but can show from time to time).
I tried to extend the FreeSync range with CRU from 40-60 to 25-60 but doesn't change anything, unfortunately.
So currently, I'm trying to either:
-Fix the flickering on borderless windowed mode, to keep the Windows HDR on
or
-Fix the HDR that disabled when I switch on full-screen, like that I will only have to switch to full-screen mode to get rid of the flickering, if not fixable
And not that easy to fix. ^^
So far, the only fix I found for Windows HDR enabled on full-screen is this: https://answers.microsoft.com/en-us/win ... d31?auth=1 but I lose the G-SYNC.
Does anyone has faced this kind of issue?
Thanks.
EDIT: On 60FPS limit, the issue seems also to vanish, but everything in between (30-60), flickering comes back.
