Overclocking AOC CU34G2X
Posted: 27 Jun 2020, 15:46
Does anyone have experience with bypassing input not supported black screens when overclocking? I have tried everything possible to overclock this monitor past 144hz, including CRU, messing with freesync, and etc. The only thing I found to work was PBP with two displayport inputs, and could get each screen to 1720x1440@144hz. Therefore it's capable of much more.. The nixeus edg34 has the same panel and is supposably overclockable to 200 hz. I have tried the benq softmccs trick and it didn't work.
For anyone with hardware knowledge, I haven't found any firmwares, nor information, although in softmccs it says a realtek scaler. I also have pictures of the board, t-con and usb controller so if anyone can help, thank you.
