AW2720HF abnormal overdrive artifact (horizontal text bleeding, and square shape alias ghosting)
Posted: 18 Jul 2020, 15:04
Recently, I bought a AW2720HF, motion clarity is quite good. But there is an issue with abnormal overdrive artifact.
For all other monitors I owned (AW2518HF, and others), the overdrive only cause inverse colored ghosting effect, which is what I expected. But this AW2720HF is completely different, it behaves really weird!
Background:
There are {fast, super fast, extreme} in overdrive setting.
Setting.........|.....G-sync Off.....|....G-sync On
Fast.............|.....minor...........|....no artifact
Super Fast.....|.....significant.....|....minor
Extreme........|....even more.....|....significant
(Following description will assume G-sync off)
1. In web browser, with super fast setting (or extreme setting with G-sync on)
when scrolling text vertically, text bleeding into the background "Horizontally"!
This can be noticed even with the lowest overdrive setting, just in much minor level.
2. In game, with super fast setting (or extreme setting with G-sync on)
edges/outlines with shape of diagonal line or circle, there are "square shaped alias ghosting", imagine stairs shaped ghost besides outline of objects. Those square are around 6x6 pixel size, and are actual square shape alias, NOT "something blur and looks similar to square alias".
Both two issues are quite a big deal, it completely blocks me recognizing text while scrolling, and the outlines look insanely weird in game. It is completely different from inverse colored ghosting, and probably hard to imagine if someone never had such issue.
Of course, if just turn down overdrive and use the lowest level, then the artifact is minor. But I occasionally want to use higher overdrive setting in games as preference, and expects the only draw back should be inverse colored ghosting.
I was using AW2518HF before AW2720HF, and it has no such weird overdrive artifact. (faster overdrive just cause more inverse ghosting, nothing like horizontal bleeding or square shape alias.)
So, here I need your help. I want to know, is this a common issue for IPS panel 240Hz monitors, or it is a common issue for all AW2720HF, or it is just me unfortunately got a defected one?
If this is a common issue, hopefully you will come in and confirm the issue to me. If I am the only one, then I will probably take a bit time uploading image or video of this weird artifact issue.
Background:
