V-Sync off or on with frames capped at 190.
Posted: 08 Aug 2020, 12:20
Hello everyone, I recently purchased a XL2546 and was wondering if I should still run V-Sync. Now I know it is recommend normally to cap fps a few frames lower than max Hz, and use g-sync and v-sync.
However, since my main game (Apex) seems to run poorly over 200fps I am going to keep it capped at 190. Since my fps will be so much lower than the 240 Hz my monitor will be running on, would it be beneficial just to turn V-Sync off?
