Enable G-Sync compatible monitor through nvidia inspector on Win7?
Kertwaii
Post by Kertwaii » 11 Aug 2020, 23:32
Anyone has a G-Sync compatible monitor working connected to nvidia gpu?
Can someone export whole settings data through nvidia inspector before and after enabling G-Sync compatible option?
I am investigating if it can be done using inspector on win7, because the option never appears in driver control panel
Glarbstintenford
Re: Enable G-Sync compatible monitor through nvidia inspector
Post by Glarbstintenford » 25 Aug 2020, 23:27
I use an HP 25x with an RTX 2060 super.
Hope this helps!
HP 25x + 2060 Super.7z
(2.18 KiB) Downloaded 343 times
Kertwaii
Post by Kertwaii » 30 Aug 2020, 04:42
Thanks.
Unfortunately (as expected) this doesn't work.
Glarbstintenford
Re: Enable G-Sync compatible monitor through nvidia inspector on Win7?
Post by Glarbstintenford » 31 Aug 2020, 19:05
No problem! Let me know if you need anything else at all.
I might install Win7 to test out some other things so I will also see if I can get it working and let you know if I happen to succeed.
