Here's hoping it will also have low input lag and single strobe at 60hz for our retro gaming freaks.
UPDATE: Strobing only at 144 and 240hz.
EDIT:
Furter info about the monitor in this reddit post.
TL;DR:
$699
24.5" IPS panel with AG coating, 400 cd/m² (typical/HDR on), HDR 10
DisplayPort 1.4 and only HDMI 2.0 (Which means that one will probably have to use DP to get 360hz)
ULMB only at 240hz and 144hz, judging from the post. (Hopefully turns out to be false.)
UPDATE: It did not turn out to be false. Bummer.
Just regular ULMB... no ULMBS or ELMBS, which would mean u could use G/Free-sync, together with strobing.
UPDATE: Same here. Bummer.
UPDATE: From the LTT vid, it looks like this monitor has more trailing than older 240hz TNs.
EDIT 2:
LTT's review is out, and they even gave credit to us!!!
