AOC 24G2U pixel-walk/inversion. Is it normal?
Posted: 25 Sep 2020, 14:32
Hi, I bought an AOC 24G2U monitor and when using it with a 60hz refresh rate noticed some faint wavy horizontal lines, specially with solid colors like the in the Eizo (https://www.eizo.be/monitor-test/) defective pixels test and uniformity test with 25% grey tone. They are faint but noticeable, crawling across the image.
After some more testing, I found that the monitor fails the lagom inversion test (http://www.lagom.nl/lcd-test/inversion.php) exhibiting noticeable flickering on patterns 1 and 3. If I use a refresh rate over 100hz the problem seems to disappear, but on all the LCD monitors that I tested no (or very minor) flickering is present. Of course none of these monitors are high refresh rate.
Is this normal behaviour of this kind of monitor at 60hz, or of the 24G2U in particular? Thanks!
