Benq XL2411K (Blur buster Utility)
Posted: 30 Oct 2020, 06:49
by Angel Soler
Hello everybody.
Is the new BENQ XL2411k compatible with Blur Buster Utility?
Can you apply the single strobe for 60 hz (play on consoles)?
I have the XL2411P, and was thinking of swapping it out for the XL2411K.
The other question would be: In case it is compatible. Would you get a better result (less crosstalk) than with the XL2411p?
Thank you very much
Greetings and take good care of yourself
Re: Benq XL2411K (Blur buster Utility)
Posted: 30 Oct 2020, 11:27
Angel Soler wrote: ā30 Oct 2020, 06:49
Hello everybody.
Probably, yes -- at least with the force feature (hit "F" key in Strobe Utility). Every BenQ monitor in the XL series (except the early models that used LightBoost, such as XL2420T) have been made compatible. I must warn you that I have not tested this model, however.
This is untested but historically every single XL2411 model (XL2411T, XL2411, XL2411P) has remained 60Hz single-strobe compatible.
It's DyAc retroactively ported to the older XL2411, so probably will provide brighter strobing than the previous monitors. However, crosstalk probably will be unchanged, if the panel is the same as before. 11
Posted: 30 Oct 2020, 11:52
by Angel Soler
Thank you very much, Chief !!
You are very kind , as always.
Hope you're well !!
I think I'm going to buy the monitor.
Looks like an upgrade from the XL22411p.
Console games at 60 hz must look very smooth and great
Greetings
