Any downside to running G-Sync in Windowed Mode?
Posted: 07 Nov 2020, 14:18
by nursejoy
So I found out that running G-Sync while the computer is in windowed mode somehow bypasses DWM. I wanted to know how and why that happens? And if there is not an answer that is fine; however what is the downside of running G-Sync in Windowed mode? I noticed it is disabled in the NVCP.
Re: Any downside to running G-Sync in Windowed Mode?
Posted: 07 Nov 2020, 14:45
by jorimt
nursejoy wrote: ↑
07 Nov 2020, 14:18
It appears to change the flip mode of the window when focused, bypassing extra composition, at least in my original tests.
nursejoy wrote: ↑
07 Nov 2020, 14:18
Overall frametime and game performance usually isn't as good as exclusive fullscreen, as the system isn't dedicating quite as much resource to the game app in borderless/windowed mode (that, and borderless/windowd adds DWM composition and forces an OS-level triple buffer V-SYNC method to the window at default).
Some games work better in G-SYNC borderless/windowed mode than others.
If you do use it, I recommend this configuration, as per an entry in my Closing FAQ:
https://blurbusters.com/gsync/gsync101- ... ttings/15/
Your “Optimal G-SYNC Settings” say I should only “Enable [G-SYNC] for full screen mode” in the NVCP, but what about for games that don’t offer an exclusive fullscreen option?
My Optimal G-SYNC Settings are just that: optimal.
Thus, while G-SYNC (and any game with any syncing solution, for that matter) typically performs best in exclusive fullscreen, it is true that not all games support this mode, so use of G-SYNC’s “Enable for windowed and fullscreen mode” is necessary for games that only offer a borderless or windowed option.
Do note, however, that G-SYNC’s “Enable for windowed and full screen mode” can apply to non-game apps as well, which will result in stutter and slowdown when affected app windows are dragged and/or focused on due to unintended VRR (variable refresh rate) behavior.
As such, it is recommended to keep G-SYNC set to “Enable for full screen mode” globally, and then to use Nvidia Profile Inspector (download here) to set both “G-SYNC – Application Mode” and “G-SYNC – Global Mode” to “Fullscreen and Windowed” per game profile, as needed:
Posted: 07 Nov 2020, 14:53
by nursejoy
jorimt wrote: ↑
07 Nov 2020, 14:45
nursejoy wrote: ↑
07 Nov 2020, 14:18
nursejoy wrote: ↑
07 Nov 2020, 14:18
So lets say I only want to do this for one application. Where do I choose it from the NVCP or the Profile Inspector?
Posted: 07 Nov 2020, 15:18
by jorimt
nursejoy wrote: ↑
07 Nov 2020, 14:53
As the last line of the previous instructions I quoted stated, Profile Inspector. Search up an existing or create a new profile for the exe you're targeting in Inspector, and then select and apply the pictured parameters for the given profile.
Posted: 07 Nov 2020, 15:39
by diakou
jorimt wrote: ↑
07 Nov 2020, 15:18
nursejoy wrote: ↑
07 Nov 2020, 14:53
Hm, this would probably be the correct / best way to configure g-sync for Brawlhalla? The game's a DX9 (adobe air) game with no fullscreen exclusive mode or a correct flip model in borderless. Meaning it is facing the full wrath of DWM with no resource focus on the game itself. Getting g-sync to work in this game seems pretty much impossible / it won't work, but doing it with the NVCP + NV Profile Inspector trick here might be able to pull it off? Being able to bypass or work better with DWM to prevent the ridiculous v-sync delay would be a huge benefit @ the 60fps locked game it is.
Posted: 07 Nov 2020, 15:47
by jorimt
diakou wrote: ↑
07 Nov 2020, 15:39
I happen to own Brawlhalla and just tested this, and I can confirm G-SYNC is fully engaged for me when the Brawlhalla profile in Inspector is set to "Fullscreen and Windowed."
I can't currently speak to input lag levels between various configurations in this particular game, as I've never tested it in that respect though.
