Hello! I recently got a new monitor and was hoping some of you who are more tech savy could help me out. I've looked online a lot for an answer to my problem, but haven't been able to find anything that works.
I recently got an off-brand monitor for cheap from newegg. It's a KUU MH270UG 4k monitor with a refresh rate of 60hz. I use the 4k 60hz for movies and non-competitive games, but when I play games like Overwatch I set it to its 1440p 144hz setting. The monitor is a freesync model, so it's not necessarily supposed to work with g-sync, but it does work every time when I use it in 4k 60hz.
The problem I'm facing, though, is when I use the 1440p 144hz setting. Sometimes it will work without error, but most of the time my monitor will turn black and say "Not Supported" and I will have to disable g-sync. The odd part is that I don't change any settings on my end to make it work, it just works randomly sometimes. This holds true even for the same game. For example, sometimes it works when I play Overwatch, sometimes it doesn't when I play Overwatch, even though I'm making 0 settings changes - it seems random.
I tried looking online for awhile to see if anyone had a problem like this, but I haven't come across this specific issue. In case it's relevant, my monitor has a 1.2 DP port and 1.2 DP cable hooked up to it. Any help would be appreciated - TY!
G-sync only working sometimes
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — BFI / ULMB / ELMB / DyAc / framegen / LSS / etc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory: Display Science Section
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
