G sync causing eye strain on Dell 27 Gaming Monitor | S2721DGFA?
Posted: 23 Dec 2020, 20:24
by The Mike
So I got this Dell 27 Gaming Monitor | S2721DGFA, and I really love it.
However, I noticed today that I haven't enabled g sync, so I did.
However, I immediately noticed I fast began to get eye strain. Is this normal or should g sync not affect this in any way?
Can it be something else?
Re: G sync causing eye strain on Dell 27 Gaming Monitor | S2721DGFA?
Posted: 24 Dec 2020, 16:00
by thecorningrove
Interessting.
I had to sell my DELL 2721dgf because of eyestrain, but I always had g-sync enabled. I thaught it's the nano ips panel, but I found out, that it also uses PWM/flickering (on very high HZ tho).
Posted: 24 Dec 2020, 16:04
by 74tm
It is most likely the wide color gamut from the Nano-IPS panel, many people have had problems with these monitors. I'd recommend returning it for the 27GL83A-B which uses a normal IPS panel instead.
Posted: 25 Dec 2020, 07:13
by Aldagar
Both the Dell and the LG use the exact same panel, it's just the LG is clamped to sRGB by default.
Posted: 26 Dec 2020, 13:13
by ELK
Sorry to be this guy, but have you tried turning the backlight down?
