Need help with XL2411P
nklvjvc
Hello, i have weird problem with my monitor as can be seen in images i posted (these are in 1024 and 1280 resolutions but its same in others), there are some shadows visible around crosshair. Hopefully someone can help me fix the issue. I am using benq XL2411P and rtx 2060 which are connected via displayport. Picture mode is standard. I tried switching displayport to under port in gpu, updating nvidia driver, deleting one with ddu and letting windows install it, installed XL2411P WHQL driver, chaning from 144 to 120hz. Nothing helped, anything else i can try? Thanks
- 132744151_159169242209199_3869336022059647341_n.jpg (384.12 KiB) Viewed 3006 times
- 132778125_2857240677856616_3215033581089176360_n.jpg (475.45 KiB) Viewed 3006 times
- 132764719_423503112178854_7934691447232268960_n.jpg (379.32 KiB) Viewed 3006 times
