G-sync and clockplatform
Posted: 29 Dec 2020, 14:58
Yesterday I was fiddling around with the following CMD commands:
bcdedit /set useplatformclock No (or false)
bcdedit /set useplatformclock Yes (or true)
bcdedit /set disabledynamictick Yes
bcdedit /set tscsyncpolicy Enhanced
bcdedit /deletevalue useplatformclock
After using bcdedit /set useplatformclock No, my G-sync became much smoother than before, it was almost unreal. No more micro-micro-stutters. I used WinTimeTester to check for any timing differences. My previous frequency was 3.22265 MHz and after the command it was something like 3.22270 or something close but still different. Furthermore I used TimerResolution tool to set my timer to 0.5 seconds
Previously it would be set to 0.5004, but after the command it became 5.007 so there was a difference.
My current settings before tweaking everything were:
3.22265 MHz timing
HPET disabled in device manager
I'm not sure what happened but then I rebooted my PC after enjoying the new smoothness for awhile, it reverted back to the old 0.5004 timing and nothing was smooth anymore. micro stutters were back.
Now no matter how many different combinations of these commands I use, I can't get the old timing back and I'm not sure what's going on but now everything feels horrible. No more smoothness.
I'm not sure what I did and I want to find out so I can get G-sync working again. I've had micro stuttering issues with G-sync for 4 years now and I'm tired of it.
3.22265 MHz timing
