Asus Rog XG248Q - G sync On and no DP signal
Posted: 05 Jan 2021, 04:53
Hello to everyone and happy new year.
When I start a game like Fortnite, Battlefield 1 or Warzone my screen goes black and loses the DP signal, I will have to press the ALT + tab to have the video signal reset.
Even when I start Warzone, it automatically sets the monitor to 60 or 100hz. (Only with Warzone)
It only happens if I have G-sync enabled. If G-sync is off everythings works fine.
I have tried with different driver versions, even the ones that should fix the problem but didn't work.
I have tried different DP cable.
I have always used DDU
My specs: I7 8700K, RTX 2080 Strix, actually I use last version of nvidia driver
