[News] AOC g2460Pg G-Sync monitor to hit UK this month
Re: [News] AOC g2460Pg G-Sync monitor to hit UK this month
Post by Chief Blur Buster » 09 May 2014, 10:48
smbrm
Post by smbrm » 09 May 2014, 14:49
Will g-sync monitors only have display port connectivity. Appreciate that g-sync may only work on display port, but does that mean monitor will be limited to only display port connections?
Post by Chief Blur Buster » 09 May 2014, 15:43
No, not necessarily.
There will be GSYNC monitors that have other ports available (at least in non-GSYNC mode).
Just that they were not on the first released models.
fateswarm
Post by fateswarm » 14 May 2014, 14:07
"Availability pushed back to late June and 3D Vision support confirmed."
http://pcmonitors.info/aoc/aoc-g2460pg-g-sync-monitor
Confirmed to have strobing, though that's expected.
Blue_Ninja0
Post by Blue_Ninja0 » 04 Jun 2014, 05:18
Any news regarding the release date of this monitor?
What is the overall quality of AOC monitors? I'll find myself having to choose between the ASUS and AOC.
aidanr
Post by aidanr » 18 Jun 2014, 19:09
smbrm wrote:Will g-sync monitors only have display port connectivity. Appreciate that g-sync may only work on display port, but does that mean monitor will be limited to only display port connections?
Looks like this one will be. Also from these pics it looks like there will be an external power brick, I've only had monitors before with a kettle plug type connector, anyone know of any pros or cons to having an external brick?
http://www.pcpop.com/doc/pic/003161033.html
http://www.pcpop.com/doc/pic/003161035.html
Post by RealNC » 18 Jun 2014, 20:07
aidanr wrote:Also from these pics it looks like there will be an external power brick, I've only had monitors before with a kettle plug type connector, anyone know of any pros or cons to having an external brick?
It means no ventilation shafts, which in turn means no dust or the possibility of small insects to melt themselves into the panel and be visible there for all eternity.
aidanr
Post by aidanr » 19 Jun 2014, 08:17
Also it moves a potential point of failure to an easily replaceable power brick. I like it.
aidanr
Post by aidanr » 19 Jun 2014, 08:48
Looks like this has slipped to July
http://www.aoc-europe.com/no_cache/en/m ... howUid=351
