Assassins Creed Valhalla does not recognize Gsync
FlavioPlaza
Post by FlavioPlaza » 08 Jan 2021, 19:04
Basically this game is the only one that when I enter the hz rates are fixed at 144, so I suppose it is not recognizing Gsync. I already checked and the game is in full screen. Any solution?
Re: Assassins Creed Valhalla does not recognize Gsync
Post by jorimt » 08 Jan 2021, 19:51
FlavioPlaza wrote:
08 Jan 2021, 19:04
1. Make sure your framerate or framerate limiter is 141 FPS or under (G-SYNC does not engage with framerates above the refresh rate).
If that doesn't work, try to:
2. Disable fullscreen optimizations for the game exe.
And if that doesn't work, try to:
3. Temporarily change G-SYNC to "Enable for windowed and full screen" mode under NVCP > Set up G-SYNC (if you haven't already).
FlavioPlaza
Post by FlavioPlaza » 09 Jan 2021, 11:18
jorimt wrote:
08 Jan 2021, 19:51
FlavioPlaza wrote:
08 Jan 2021, 19:04
I noticed that this happened after activating Vsync through the Nvidia control panel. If I disable it via the panel and activate it within the game, it will recognize Gsync. Could this be a game engine mismatch?
Post by jorimt » 09 Jan 2021, 13:55
FlavioPlaza wrote:
09 Jan 2021, 11:18
Could be a game and/or driver-specific issue then. There's no harm in using G-SYNC with in-game V-SYNC in this case if that's the only way you can engage it in this game.
