Hi everyone,
I recently purchased a new certified g-sync compatible lg monitor. 1080p @144hz and im having severe difficulty getting it to work properly with gsync. It is setup correctly as per this sites instructions (gsync on, vsync on in NVCP, vsync off in game, and im using the frame rate limiter in NVCP at 141) but I'm having microstutters in most games I play. This includes ESO, Greedfall, pathfinder kingmaker, and many others. Along with the microstutters I seem to feel a kind of slow down or smearing effect that gives me headaches if I turn the camera too quickly.
I would say this is the monitors fault but I recently came from a viewsonic xg2402 and experienced the exact same issues on it as well. The only partial fixes that have done anything in my testing are the following:
Turned off vsync in nvcp (tearing in the bottom of the screen although sometimes the smear slowdown effect seemed to dissipate when turning the camera)
Keeping vsync on in nvcp but turning off the frame rate limiter seems to help with some of the microstutters but not completely.
My build is
I7 7700k
1080ti
1 terabyte ssd
16gb of 3200 ram
windows 10 pro 64bit
Any help would be greatly appreciated!
Issues with optimal G-sync settings.
- jorimt
Re: Issues with optimal G-sync settings.
G-SYNC does not eliminate system-side stutter, motion blur or overdrive artifacts. It only eliminates traditional V-SYNC-induced stutter, and input lag, along with tearing inside the refresh rate.Beachwrack wrote: ↑18 Jan 2021, 09:48I'm having microstutters in most games I play. This includes ESO, Greedfall, pathfinder kingmaker, and many others. Along with the microstutters I seem to feel a kind of slow down or smearing effect that gives me headaches if I turn the camera too quickly.
Also, unlike G-SYNC monitors containing hardware modules, the majority of G-SYNC Compatible monitors do not support variable overdrive, which can affect the appearance of ghosting/overdrive artifacts during variable framerates in VRR mode (dependent on the monitor model).
TTT
If it happens on 2 different monitors, its more than likely your PC or the way you have your PC set up causing it.
Beachwrack
Thank you for the fast responses. I assumed that the actual certified compatible monitors would perform better than the uncertified ones such as the xg2402. I will say this, I remember gsync working more effectively (cleaner) on a precious nvidia update on my old monitor.
Last point I would like to discuss is after calling the Nvidia support line, they told me that certified compatible monitors will not work as they should with my 1080ti. They said they only work well with the rtx generation. Module gsync monitors will work with my gtx generation though. Is any of that true? I had never heard that before.
Thank ya'll again for all your help.
- jorimt
Native G-SYNC will have variable overdrive, which will reduce ghosting during VRR operation, but, fair warning, like G-SYNC Compatible, it won't reduce or remove motion blur or system-side stutter.Beachwrack wrote: ↑19 Jan 2021, 12:57I assumed that the actual certified compatible monitors would perform better than the uncertified ones such as the xg2402.
G-SYNC Compatible requirements are 10 series or higher, so you're covered there:Beachwrack wrote: ↑19 Jan 2021, 12:57Last point I would like to discuss is after calling the Nvidia support line, they told me that certified compatible monitors will not work as they should with my 1080ti. They said they only work well with the rtx generation. Module gsync monitors will work with my gtx generation though. Is any of that true? I had never heard that before.
https://nvidia.custhelp.com/app/answers ... /related/1
Perhaps support was referring to overall performance improvements of the newer RTX cards, which would allow a higher sustained framerate within the VRR range?
