HDMI to DisplayPort
All newer XBOX consoles supports 120Hz+ & FreeSync. Getting help with getting "Better Than 60Hz" on the XBOX ONE, XBOX Series S, and XBOX Series X, as well as the PlayStation 5.
Fall
HDMI to DisplayPort
Post by Fall » 23 Jan 2021, 15:26
I tested the "Benfei HDMI to DisplayPort Adapter" at 120HZ on the ZOWIE XL2411P 144Hz. The adapter is necessary for this model because the HDMI chip has a max throughput of 60HZ @ 1080p.
Will using this adapter to translate the signal reduce the benefit of 120HZ (when the goal is lowest input delay)? - Is it possible to measure/test delay when using this adapter?
The adapter isn't a long term solution...i'd appreciate any feedback.
Monitor: https://zowie.benq.com/en/product/monit ... 2411p.html
Adapter: https://amazon.com/gp/product/B0752D33PJ/
Model Number 000152black
[Editor note -- Linkified your links as they are approved]
Re: HDMI to DisplayPort (??) | XL2411P @ 120HZ
Post by Chief Blur Buster » 26 Jan 2021, 04:17
A DisplayPort-to-HDMI conversion and vice-versa, can be relatively unbuffered (just line buffer / packet conversion). In theory, this adaptor would only add an insignificant latency.
Fall
Post by Fall » 28 Jan 2021, 12:03
26 Jan 2021, 04:17
Thank you for your explanation. :D hope this information is helpful for other people, too
