Any AW2521HF/HFL owners?
Hello, any owners of this alienware? I was wondering how is the swivel on this monitor, how much left/right can I actually turn it?
Re: Any AW2521HF/HFL owners?
It's very good. However, I find the monitor blurry at 240 fps and I'm sending it back. As example, I cannot play Children of Morta with this monitor because blurriness makes me dizzy.
I too own the monitor and am very happy with it. It also has the best white balance / color accuracy out of the three 240hz IPS monitors I tested. Input lag is extremely impressive and even on the super fast overdrive setting, where i don't see any artifacts, overall very pleased.
With it being 240hz though, you can't always get that FPS in all games as it requires a lot of juice, so keep that in mind. Definitely one of the best all-round 240hz monitors out there currently.
Should I use Fast or Super Fast?Suibom wrote: ↑26 Jan 2021, 01:11I too own the monitor and am very happy with it. It also has the best white balance / color accuracy out of the three 240hz IPS monitors I tested. Input lag is extremely impressive and even on the super fast overdrive setting, where i don't see any artifacts, overall very pleased.
And by the way, do you find the screen bright enough? I'm coming from a TN 240Hz 1440p Lenovo and I felt it was way brighter, I set it on 100% in the OSD, is there any way to make it brighter?
And in NVIDIA do you see it as HFL or HFLA?
Thanks in advance
- 5e9b15f426121af45eb8a4bace0a7077.png (6.2 KiB) Viewed 3305 times
