VT 1350 trick
swag
VT 1350 trick
Post by swag » 10 May 2014, 14:15
hello everyone, i just updated my monitor using linux method by pipomolo42 thank you very much dude
i did the trick 2020/1350 vt and the image is not brighter it's the same, im using amd gpu
what could be the problem?
also when i was updating the firmware in the last part verify firmware it failed but it update the firmware fine and i also turned the burn in mode off, i checked the service menu v002. using the strobe utility too great app thanks pipomolo42 and chief you are the best
Falkentyne
Re: VT 1350 trick
Post by Falkentyne » 10 May 2014, 18:17
It will only be very slightly brighter in blur reduction mode. And you may need toastyx's pixel clock patcher, if the pixel bandwidth exceeds 329 MHz, otherwise it will ignore the changed timings.
