Hi
I am having some problems to choose a monitor for Microsoft Flight Simulator.
I had a lot of statements and it is getting really confused until now. HDR, HRR, VRR, G-Sync, G-Sync adapt, G-Sync compatible... and endless discussions which makes this process very confusing...
First, the specs and the needs:
1. I have i9-10900K with Asus ROG Strix RTX 3090 OC 24GB
2. I would like to run MSFS in a 2K resolution (2560x1440), not so expensive, by Asus/LG/MSI if possible.
I would like to know if the following options are good for MSFS, and if not, why:
Asus TUF GAMING VG27AQ1A
Asus TUF Gaming VG27AQL1A
LG 27GL850-B Ultragear
MSI Optix MAG274QRF
The game is always giving 20 to 60 frames depending on the area, if scenery is complex or not.
The problem is that none of these monitors are G-Sync native (these ones are expensive...) and their refresh rate start on 40 or 48 and not on 1. So, how to avoid tearing and stutters? I know there are some calculations for these monitors in order to avoid those problems.
Questions:
1) Can I buy one of those monitors? If not, I am waiting for more options. However we always have to take in account that monitors with RR starting in 1 are expensive and almost impossible to get in my country.
2) Which settings I have to choose in order to have a good performance and avoid stutters, tearing and other problems?
Thanks.
New monitor for MSFS
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — BFI / ULMB / ELMB / DyAc / framegen / LSS / etc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory: Display Science Section
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
