tested the keyboard polling rate and found 1000hz. How is this possible?
Posted: 21 May 2021, 13:13
by 224dj
http://blog.seethis.link/scan-rate-estimator/
I pressed any key, but the shortest key press was 1 ms.
My keyboard is RAZOR Blackwidow linear and I use the Razor yellow switch.
There is no debounce time on my keyboard, and the scan time is 1000hz and the polling rate is 1000hz?
I thought all mechanical keyboards had 5ms of debounce time, is this a lie?
Re: tested the keyboard polling rate and found 1000hz. How is this possible?
Posted: 23 May 2021, 21:11
by Slender
as I envy you, my keyboard software does not work even after I set 1000hz. 22ms.....
