Strobbing on the Viewsonic xg270
Samuraixxx92
Can I use anti motion blur strobbing up to 240 hz on the Viewsonic xg270?
Re: Strobbing on the Viewsonic xg270
Yes you can. XG270 can strobe at any refresh rate from 75Hz to 240Hz -- even custom refresh rates in between.Samuraixxx92 wrote: ↑01 Jun 2021, 13:58Can I use anti motion blur strobbing up to 240 hz on the Viewsonic xg270?
All Blur Busters Approved monitors always have a strobe continuum (strobe any Hz in a range), rather than a few presets (like NVIDIA ULMB 85Hz, 100Hz, 120Hz)
However, if you want more refresh rates & better strobe flexibility, consider the upcoming XG2431 which is Blur Busters Approved Version 2.0 and can strobe any Hz 59Hz to 240Hz. It currently has a better-quality IPS 240Hz strobe that is competitive with TN 240Hz strobe.
XG2431 also can single strobe 60Hz which is excellent for viewing legacy 60fps content, including sports videos, consoles and emulators.
Samuraixxx92
Ok thanks. I went ahead and bought the xg270!Chief Blur Buster wrote: ↑01 Jun 2021, 15:13Yes you can. XG270 can strobe at any refresh rate from 75Hz to 240Hz -- even custom refresh rates in between.Samuraixxx92 wrote: ↑01 Jun 2021, 13:58Can I use anti motion blur strobbing up to 240 hz on the Viewsonic xg270?
I assume you can only strobe when G-sync is disabled?
