Does Geforce Experience overlay add input lag?
Randomizer23
Hello, I mainly currently play Valorant pretty competitively and I also like RPG's such as The Witcher 3. Because of this I downloaded Geforce Experience to take advantage of Ansel to take screenshots in The Witcher 3. Though, because it adds an overlay which is acitvated by pressing Alt + Z, I am worried that it will be adding input lag for games I do not need it on such as Valorant. Keep in mind im talking about when the overlay is NOT on the screen. Even if it is NOT on the screen does it still add any input lag?
deama
Re: Does Geforce Experience overlay add input lag?
Fr33thy did a chart on this and apparently he got better fps and better input lag on his valorant tests, about 20% improvement, but that's comparing it to a fresh windows install, doesn't seem to make much of a difference if you do some basic tweaks, which you may or may not have done.
Here's the link to the chart: https://docs.google.com/spreadsheets/d/ ... edit#gid=0
The first part is him measuring fps, if you go further down he measures the input lag.
