Glitch screen on XL2546K @240hz when signing out
phaze
Post by phaze » 15 Jul 2021, 13:35
Hey guys,
I just purchased the XL2546K and I realized something happens when I signout only @240hz, The screen glitches as shown here
https://imgur.com/a/xisGvtB
I reinstalled Windows, tried the combo for Restarting GPU (Ctrl + Shift + Win + B)
Tried Reinstalling GPU Drivers and trying old ones.
Still can't get to fix it.
Can't identify if its from the GPU or The monitor.
axaro1
Re: Glitch screen on XL2546K @240hz when signing out
Post by axaro1 » 15 Jul 2021, 18:07
I've tested two different XL254K units and neither of those two had the issue that you described.
It looks like a defect, what cable are you using?
*= currently owned
CPU: 5800x3d 102mhz BCLK
GPU: 3080FE undervolted
MOUSE: Endgame Gear OP1 8k
KEYBOARD: Wooting 60he
phaze
Post by phaze » 15 Jul 2021, 19:07
axaro1 wrote: ↑
15 Jul 2021, 18:07
Display port the one that came with the monitor
phaze
Post by phaze » 28 Jul 2021, 02:43
Post by RealNC » 28 Jul 2021, 08:28
Check the monitor OSD to see if it switches refresh rate. If yes, then it's perfectly normal.
phaze
Post by phaze » 28 Jul 2021, 11:01
Nope, it doesnt change the Refresh rate.
