Locking 48fps on 143.981hz monitor
warface9991
I have LG 24GL600F monitor. It's 144hz monitor but it's actually and normally not precisely 144hz. So, I want to divide 143.981hz by 3 but as you know it's not possible to write that numbers on RTSS. My question is: how can I divide this number by 3? Or should I not care to divide it precisely and set fps limiter to 48fps? I don't want it to judder as well. Thank you for all questions in advance.
Re: Locking 48fps on 143.981hz monitor
1 -- You can use a Custom Resolution Utility and create a more divisible resolution like (23.976fps * 6) or (24.000fps * 6). CRU software like ToastyX CRU and NVIDIA Control Panel lets you create custom refresh rates in 0.001 Hz increments.
2 -- You can use a VRR-compatible video player. If you have a Radeon card, you can use ToastyX CRU to edit FreeSync range a bit lower, such as 45Hz, to give room for 48fps without LFC, and use a precision framepaced player. I'd recommend SMPlayer/MPV as a VRR-compatible player that can play any frame rate within FreeSync range. This is easier at 60fps, since 48fps is often at FreeSync's minimum Hz and may cause LFC stutter, but you can tweak your way out of LFC, even using a higher VRR minimum to force 96Hz LFC for 48fps material.
3 -- You can test the player and see if it plays without stutter visible to your eyes. For a well-framepaced video player, it is only a rare 1/6th stutter (17% deviation), much less visible than a stutter at 24Hz (100% deviation) or 48Hz (50% deviation).
Basically, the judder-jump would only increase/decrease by 17%, and you might not care. That said, there would be a far bigger judder/stutter problem with 60fps video material than with 24fps video material.
warface9991
Thanks for your detailed answer, really. But I actually asked about gaming framerates. I am really sorry for not specifying the question and spending your time for the detailed answer.Chief Blur Buster wrote: ↑24 Jul 2021, 20:371 -- You can use a Custom Resolution Utility and create a more divisible resolution like (23.976fps * 6) or (24.000fps * 6). CRU software like ToastyX CRU and NVIDIA Control Panel lets you create custom refresh rates in 0.001 Hz increments.
Dr. Asif Khokhar is the best eye surgeon in Lahore. He is a known best eye specialist in lahore who has expertise in the latest technologies of eye treatments, with experience of over 30 years and treatment of diseases that affect eyes. Dr. Asif Khokhar is also a member of American Academy of Ophthalmology (USA). They focus on regular vision care and prescribe eyeglasses and contacts. Dr. Asif Khokhar oculoplastic surgeon in lahore perform eye exams, treat conditions like nearsightedness, farsightedness, and astigmatism and also prescribe and fit eyeglasses and contact lenses to the patient. Here i want a solution regarding promotion of better Ophthalmology services in Pakistan as squint eye specialist in lahore.
