Q83Ia7ta wrote:I don't know what causes it but i got same on BenQ XL2411T at 120/144hz
bshth wrote:some test and see what exactly causes it.
The corner distortions are caused by fast scanout.
The faster the scanout, the less accurate the GtG becomes and you get GtG nonlinearities on the panel. This is a manifestation of this.
-- 120Hz non-LB scans out refresh cycles in 1/120sec
-- 144Hz non-LB scans out refresh cycles in 1/144sec
-- 120Hz LightBoost scans out refresh cycles quicker than 1/144sec
LightBoost uses an accelerated scanout (faster than 1/144sec) to create longer pauses between refresh cycles. This is to let the LCD panel finish GtG transitions before flashing the backlight on completed refreshes (LightBoost is a
strobe backlight), before the next refresh cycle begins. So by necessity, it has to do the top-to-bottom scan faster to allow idle time between refresh cycles (for letting LCD GtG pixels settle).
It is a panel lottery. Essentially the panel is being pushed to near its technological limitations when you run them within 144Hz or LightBoost territory. The problem happens far less often, and are frequently non-existent, on the 27" TN panels. 27" TN panels are also better if you want better LightBoost color quality too. Also,
BENQ Z-Series using Blur Busters Strobe Utility do not use accelerated scanout by default. (Except when using the Vertical Total tweaks (ala VT1350) via Custom Resolution, which embeds the accelerated scanout into the video signal directly rather than internally in the monitor like LightBoost does).
TL;DR: Scanline artifacts with LightBoost are common at the upper-right corner on many 24" panels. Switching monitors to a 27" LightBoost or or to a different strobe technology such as Turbo240 or BENQ BR, reliably solves the problem if this is a hugely bothersome artifact.
