I dont use a gsync compatible Monitor its AOC agon251fz but its a fressync. When i enable gsync it Shows to me that gsync is active and the Monitor Shows fressync active.
Am i using g sync at this Point when its Shows that its active?
Gsync on non gsync Monitor
Re: Gsync on non gsync Monitor
It sounds like it, does the monitor have a built in framerate overlay? You will be able to see on that, if the framerate isn't just sitting at max then Gsync is on.
Also on NCP when you click the Gsync selection, click display at the top and you can turn on a Gsync indicator on your PC.
