Question for 240Hz+ IPS in games like apex
Deyet
Post by Deyet » 30 Aug 2021, 06:44
Hello,
For weeks I have been trying to find a good monitor, these are my candidates:
- MSI MAG 251RX
- ASUS VG259QM
- Alienware AW2521HF
- ViewSonic XG2431 (it's not released yet but could be an option)
I play competitive games like: Apex legends, valorant, koovak (mostly apex than the others, so I would like to prioritize a monitor for this game)
Setup: i5-9400f and 1660 super, yes, I know that it is not the best for 240hz but in games like csgo / valorant it goes above 240fps so I have no problem with that, on the other side, in apex I get 100-190 fps with the lowest settings.
My question is: will I have problems with some of these monitors if I don't reach 240fps in apex? will I have higher inputlag / overshoot? I understand that the vg259qm reaches 1.9ms with a minimum overshoot only at 280hz but I don't know if it will apply to someone who plays with low fps.
BTW sorry for my english, it's not a native language for me :roll:
kyube
Re: Question for 240Hz+ IPS in games like apex
Post by kyube » 31 Aug 2021, 11:33
I'd recommend you to look into 1440p 144hz+ instead, as the higher resolution benefits BR games like Apex a lot.
https://docs.google.com/spreadsheets/d/ ... =569615273
Take a look at this spreadsheet made by r/Monitors for some good recommendations.
And no, don't worry about not hitting the refresh rate target, higher refresh rate has benefits even if you don't hit it.
Deyet
Post by Deyet » 01 Sep 2021, 04:44
Thank you!
