Acer XF250q Blurry
Posted: 18 Sep 2021, 00:22
by zabra
Any way I could reduce blur on this display? I'm using overdrive mode on extreme but other than that there isn't any other options to help with that. Does anyone know the factory menu button combination I could press to bring up hidden options? DP 1.2 cable. It appears a lot blurrier at 240hz than 60. I'm not really into monitors that much so excuse if I sound uneducated.
Re: Acer XF250q Blurry
Posted: 19 Sep 2021, 03:26
by Ragerlis
Acer monitors overdrive setting at extreme is well known to be a mess, try to reduce the overdrive setting to normal/off.
Posted: 20 Sep 2021, 10:19
by deama
You can try a software implementation of BFI, there was one floating around on blurbusters, maybe you can find the link to the github.
But it will half your hz and might cause other issues.
