vg248qe gsync bugs?
flood
vg248qe gsync bugs?
Post by flood » 01 Jun 2014, 00:03
Not sure if anyone else has reported this before, but today I played csgo for about an hour. a few times, the entire screen turned black for a frame or two and I remember seeing red/green/blue bars that flashed for a frame or so. this happened 3 or 4 times.
Anyone else seen this?
Re: vg248qe gsync bugs?
Post by Chief Blur Buster » 01 Jun 2014, 01:18
Which driver version? I noticed GSYNC bugs occur with some driver versions.
flood
Post by flood » 01 Jun 2014, 02:16
335.23
flood
Post by flood » 06 Jun 2014, 17:40
more bugs yay
cs1.6 fucks up my screen:
I play 640x480 with -nofbo in launch options and this happens
after i close cs1.6:
and then it's fixed once i open up csgo
fenderjaguar
Post by fenderjaguar » 06 Jun 2014, 18:10
I've had minor issues with the image shifting up the screen as well, but not nearly as serious. bottom of this thread for pictures:
http://forums.blurbusters.com/viewtopic.php?f=5&t=900
Griff
Post by Griff » 11 Jun 2014, 19:32
I have the same issue at times too, including the one fenderjaguar is describing. I can fix the image shifting by resetting my resolution on my desktop, however the flashing black screen I have yet to figure out. Also I have an even more annoying issue that I made a post about here: http://forums.blurbusters.com/viewtopic.php?f=5&t=976
Tricky
Post by Tricky » 12 Jun 2014, 03:30
Yeah, I'm seeing the same thing (except for the bars which I haven't). Full blackscreen for maybe ten frames in a row? It's pretty rare though, maybe less than once a week? I haven seen it dozens of times now though. Must be some kind bug so far undocumented by NVidia or Asus.
Using the vg248qe GSYNC on a Gainward Geforce 770 2mb. Windows 8.1. Using a 1000hz Logitech mouse also. Running the current beta driver for my GPU, but I'm at work now so I can't check which that is.
fenderjaguar
Post by fenderjaguar » 06 Sep 2014, 05:47
Happy to say this black frame issue is cured on the lastest drivers? I certainly haven't seen it for a few months now...
flood
Post by flood » 06 Sep 2014, 06:27
pretty sure what i was seeing was less than 10 frames
and it would happen like once every hour (very roughly). idk exactly but it was way more frequent than once a week for me
unfortunately i don't have any gsync-capable card right now to test
