While these are clandestine end-user tests, more review websites need to make field trips to extremely interference-problematic location (like a country, a city, or a house with 100x+ more interference) and do some detailed tests (e.g. a million-view YouTuber or tester).
Emulate an unfortunate part of the world where all this stuff is behind the wall behind the computer room in a cramped developing-country apartment tower. Or you're emulating a house built underneath high voltage lines -- some countries build them unusually close to the lines!
EMI is location specific. There are billions of places in the world to live, and some computer owners are just plain unlucky.
Idea #1: Computer Desk 10 Meters Under 500,000 Volt Power Lines
Bring a generator (or one of these large batteries) and set up a computer desk under the highest-voltage power transmission lines you can find within driving distance. Look at power companies and find out what voltages they use for their power lines.
Heck, bring a fluorescent tube too, find a location that glows brightest with a vertically-held fluorescent tube -- it's your defacto equivlaent of a geiger counter for the specific radation signature of power transmission.
These ordinary fluorescent tubes (like those in office) aren't connected to electricity. They're glowing from the radation emitted by the high voltage lines!
Now set up a computer desk here (on generator)! Try esports with long mouse cables underneath 500,000 volt power lines between two transmission pylons. All those cables flailing around behaves as antennas for the high voltage electricity. Even coaxial cables are no match for sufficiently strong radiation powerful enough to light fluorescent tubes.
Remember to use a glass-side computer case, so you've eliminated your Faraday Cage, with a big open barn door for electromagnetic radiation to enter your computer. (Not that the puny Faraday cages can even completely repel radation from 500,000 volt power lines, but you need to bluntly swing all doors wide open for intentional tests).
Idea #2: Intentionally Create a Noisy Electrical Environment
Or set up an array of intentional-interference like setting up all of this all at the same time in the same room:
- a 1920s fridge running concurrently with;
- a 1950s TV running concurrently with;
- a 1950s sparkgap-transmitter based japanese remote control toy, running concurrently with;
- an old dryer machine with its cover removed (to eliminate its equivalent of a faraday cage shield), running concurrently with;
- A partially leaky microwave oven, running concurrently with;
- All running in the same small room as a gaming PC in close vincinty with each other
- You can substitute these devices with known major EMI/EMF emitters. Have multiple in the same room, inches or feet away from computer. You may only need 1 or 2, or you may need a huge array running simultaneously (like a next door neighbour)
Remember To Use a Borderline Computer Where EMI More Easily Tips Domino Effects
1. Build a computer with a cheap power supply with poor power factor correction (skip the 80Plus stuff, or go Bronze only) with a budget occasionally-crash-prone motherboard
2. Push the clock limits to just before crashing (slightly overclocked computers are sometimes more interference sensitive)
3. Keep adding interference-generating appliances to the room until the computer finally starts crashing when everything runs.
4. Back it off a bit (e.g. slightly increase distance of computer away from appliances)
5. Then test the computer latencies with these devices enabled/disabled.
If the computer doesn't crash yet, find something else that does. Make sure you're using a sacrificial computer, as bad electricity (surges) can damage a computer, but many YouTubers intentionally destroy computers in the name of popular science and views... So go nuts surrounding a computer with sparking motors and ugly old industrial equipment (similar to mega air conditioners that may be hidden underneath an apartment tower's mechanical floor) and whatever interferency-stuff you can get your hands on from discarded appliances/electronics. Some countries/cities are full of these, while others are not.
This is very voodoo stuff to the main stream, but it's actually already part of university degrees in electronics design.
I suspect we could use a million-view YouTube megastar or a web reviewer, to do some tests. This is NOT Blur Busters speciality, but some parts of the world is prone to really nasty interference. Not everyone is as lucky to have great electricity and free of interference as we are.
Disclaimer: Electricity and old appliances can be dangerous! In all cases, do safety precautions, stay safe, "don't do this at home", etc.
