Hello,
I would like to buy a G-Sync laptop with a high refresh rate (240hz or more). I need the laptop screen to be G-sync, as I do not plan to use external monitor.
Could you please help me confirm that this laptop is OK with G-sync : Acer Predator Triton-PT515-52-73L3
I heard some Triton did include G-Sync but not all, depending on the model and year.
https://www.amazon.fr/Acer-Predator-Tri ... B08CNLPDXV
I also want to use BFI on it. If I understand correctly, a 300hz monitor can go 150hz BFI (because refresh rate has to be X2 compared to standard backlight strobing).
May you help me confirm ?
Thank you !
Help me confirm Triton-PT515-52-73L3 is G-sync
Hellstyx
