Possible solution to dirty electricity (EMI/RFI) in common homes
BigBoi
I may have found a universal solution to this widespread issue. Smart electric meters. Where I live (Quebec, Canada), 98% of all electric meters have been replaced with smart meters (this deployment started back in 2014) which are used to measure electric consumption and send this information real time to electric companies using radio frequency waves. Smart meters are known to contribute significantly to the levels of dirty electricity in a home. This is due to the repeated spikes and surges of higher frequencies of electricity that run throughout every circuit of a home with a smart meter. Thankfully enough, here we have the option to opt out of this and replace our meter with the old one (manual) where instead someone from my electric company would have to check the meter to estimate electric consumption for the bill. I will be calling my electric company tomorrow and replace mine with the old one. I will keep you guys updated on this matter. I'd suggest you guys also check up on this.
nyxo100
Re: Possible solution to dirty electricity (EMI/RFI) in common homes
please update us makes sense to me im 100% sure this is a electrical issue too
wadge
make sense to me too. i'm looking to buy a lithium power station to test.
I'm already on fiber so i would just have to plug my modem and pc on the power station to check if it help
Plznoinputlag
i iust bought very old meter and im waiting for the electrician to come and connect it for me,BigBoi wrote: β03 Nov 2021, 00:14I may have found a universal solution to this widespread issue. Smart electric meters. Where I live (Quebec, Canada), 98% of all electric meters have been replaced with smart meters (this deployment started back in 2014) which are used to measure electric consumption and send this information real time to electric companies using radio frequency waves. Smart meters are known to contribute significantly to the levels of dirty electricity in a home. This is due to the repeated spikes and surges of higher frequencies of electricity that run throughout every circuit of a home with a smart meter. Thankfully enough, here we have the option to opt out of this and replace our meter with the old one (manual) where instead someone from my electric company would have to check the meter to estimate electric consumption for the bill. I will be calling my electric company tomorrow and replace mine with the old one. I will keep you guys updated on this matter. I'd suggest you guys also check up on this.
all what u said its makes sense cuse ive read a lot of smart meters that causing high radiation and all this stuff but u always suspected the wiring, grounding etc.
i checked my pc in other place and it worked flawless and i checked the meter and it was very old so now i just need to give a try. sorry for my english, ill update after the replacement
delve
not for me, switching from old to new made very little difference, problem is/was present with both meters.
Plznoinputlag
BigBoi
Plznoinputlag
mine is fixed holy shit
Mugabi
U fixed it by switching from smart to dumb meter? Keep testing it more
Plznoinputlag
i changed to very old electric meter(manual) not smart and the input lag are gone. for now its all goodMugabi wrote: β04 Nov 2021, 03:28U fixed it by switching from smart to dumb meter? Keep testing it more
