XL2540k with Strobing?
Posted: 03 Nov 2021, 20:34
by Silliker
Does anyone know if the strobing utility software works with the XL2540k. If so I'm just assuming it dims it down to around 200 nits due to no voltage increase of the backlights? Could be a nice budget xl2546k though if it works though!
Thanks
Re: XL2540k with Strobing?
Posted: 04 Nov 2021, 03:22
by RealNC
Silliker wrote: ↑
03 Nov 2021, 20:34
Moved to correct forum section.
Posted: 26 Nov 2021, 06:49
by Andi1s
Silliker wrote: ↑
03 Nov 2021, 20:34
Thanks
Yes it works! I had the same question and a friend of mine actually got this monitor. The screen isn't even darker. It's straight up dyac.
Posted: 26 Nov 2021, 16:06
DyAc is indeed one of the brighter voltage-boosted strobe backlights on the market -- it dims much less than many brands.
Posted: 30 Nov 2021, 11:22
by Silliker
Andi1s wrote: ↑
26 Nov 2021, 06:49
Silliker wrote: ↑
03 Nov 2021, 20:34
Thanks
Thats great ! I want to try out Dyac and this might be the best/most cost effective way to do it !
Posted: 30 Nov 2021, 13:25
by Silliker
Andi1s wrote: ↑
26 Nov 2021, 06:49
Silliker wrote: ↑
03 Nov 2021, 20:34
Thanks
Also surprised by that I read somewhere else (another forum) that it does affect brightness
Posted: 30 Nov 2021, 14:27
by Silliker
26 Nov 2021, 16:06
Are you confirming BFI on the xl2540 is still 350 nits (approx) like the 2546k ?
Thanks
Posted: 30 Nov 2021, 15:34
Silliker wrote: ↑
30 Nov 2021, 14:27
26 Nov 2021, 16:06
Thanks
XL2540 is not marketed with "DyAc" or "DyAc+".
It does have MBR (Motion Blur Reduction) but it is not voltage boosted like the branded version (DyAc).
BenQ only markets DyAc on XL2546 series (XL2546, XL2456K).
If you want the brighter voltage-boosted strobe backlight in a BenQ monitor, look for the "DyAc" branded marketing lingo.
TLDR: Both XL2540 and XL2546 has strobe backlights. But only the 240Hz models with with last digit in "6" suffix have the brighter voltage-boosted LEDs for brighter strobing, and gains the marketing lingo of "DyAc" (Dynamic Acceleration). Pony up the $$$ for the extra strobed nits if you want. Up to you.
Posted: 30 Nov 2021, 16:24
by Silliker
30 Nov 2021, 15:34
Silliker wrote: ↑
30 Nov 2021, 14:27
26 Nov 2021, 16:06
Thanks
Awww yes , thanks for the clarification. As I suspected, perhaps too good to be true !
