I bought a new gsync monitor today so now im running two.
Acer Predator XB271HA and ASUS VG27AQ1A both are running same refresh rates(been trying 120-144-165) and are connected with DP cables.
On XB271HA I can enable refresh rate numbers on the screen which shows the current refresh rate.
My issue is that when I'm playing a game in windowed mode my second screen (ACER) will stay at 10hz and if I move my mouse over it will jump up from 10 to 30~.I also notice that the top part of the screen will start to flicker. This stops when second monitor gets focused by a click.
I tried starting an youtube video and then the hz locks to 24 and if I hover with my mouse on the actually video playing without clicking on the second monitor it bumps up to normal refresh rate ~160. If I just hover any other thumbnail or w/e it will lag and locks between 10-30.
I also noticed when I use the UFO test from blur busters the refresh rate will stay around 150-165 when the screen is not focused.
Anyone else having this issue or what can I do to solve it?
Dual G-SYNC monitors locks to 10hz.
frallan123
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — BFI / ULMB / ELMB / DyAc / framegen / LSS / etc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory: Display Science Section
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
