Skipping OLED and straight to Quantum Dots?
Posted: 03 Jun 2014, 04:40
by Edmond
http://www.techpowerup.com/201536/tpv-a ... putex.html
The switch from CRT to LCD was a trade off.
Was hoping OLED would bring the best of both together. But i am hearing OLED isnt doing too well recently. Expensive and what not.
Well... now there is QD apparently and the big argument is lower cost. I just hope it gives at least all the same stuff that OLED gives.
Re: Skipping OLED and straight to Quantum Dots?
Posted: 03 Jun 2014, 17:46
by flood
what is the reason that oleds have been used for phone and tablets but not for desktop monitors?
Posted: 03 Jun 2014, 18:19
Edmond wrote:Well... now there is QD apparently and the big argument is lower cost. I just hope it gives at least all the same stuff that OLED gives.
This is very interesting! But there's a catch; that one is still using LCD. QD is used for backlights on some screens at the moment, and not yet at the per-pixel level. I don't think they are yet doing it at the per-pixel level, or simply using QD as a backlight. Currently this QD Vision press release appears to still be using LCD.
QD backlights are already being used. Sony Triluminos are using QD-enhanced backlights now, and QD is used in some tablets like Amazon's Kindle Fire HDX 7. At the moment, it's just another backlight technology for LCD.
flood wrote:what is the reason that oleds have been used for phone and tablets but not for desktop monitors?
Cost and burn-in. Sony has multi-thousand-dollar desktop OLED monitors already, but they are for the professional market.
Posted: 03 Jun 2014, 20:48
by flood
Chief Blur Buster wrote: Cost and burn-in. Sony has multi-thousand-dollar desktop OLED monitors already, but they are for the professional market.
do those suffer from burn-in?
I suspect qd's have their own problems (maybe burn-in as well)... we'll see in a few years
Posted: 04 Jun 2014, 01:22
by RealNC
QD is there to make cheap white LED backlights perform the same as the more expensive red, green and blue LED backlights. LED backlights that are red, green and blue instead of white would not benefit from QD. But those backlights are more expensive and generate more heat.
And of course, as Chief said, this doesn't change the panel itself, which is still a normal LCD. The only thing that QD does right now, is that manufacturers add a QD "coat" between LED backlight and LCD panel, so that the QDs can take the white light from the LED and give off better colors for the LCD panel (a QD for example can absorb white light and then emit a vivid and clean red, which wouldn't be possible by just filtering the white light from the LED with conventional means.)
