240-280hz custom resolutions (ie 800x600) a problem on VG279QM or VG259QM?
MentalSharps
Post by MentalSharps » 28 Dec 2021, 10:10
I'm looking at getting one of these two monitors, but just wondering whether it's possible to play on custom resolutions with high refresh rate, ie 800x600 or 1024x768 240hz etc, in Valorant (where custom resolutions are possible using the config file). Presumably I could add the resolution using CRU, and set in game?
I play on low resolutions to increase my fps, I'm assuming that playing with say 40-60fps will be best done on high refresh rates anyway for better response time and motion clarity?
