As a notorious blurbuster user, i come here to confirm that changing my monitors colour settings to black and white only has helped reduce my input lag, it didn't get red of the problem totally but mouse became abit more lighter, i can control spray, getting headshots is easier, no more screen tearing fps dropping laggy looking things.
This could be placebo but every game i played after i did that i was top fragging and had no issue killing opponents.
Perhaps changing the colour made the visual lag and stutter appear less to my eyes which tricked me into thinking the overall lag has reduced but trust me when i say this, i really dont believe thats the case, i believe it has indeed reduced the overall input lag/lag in my game.
Give it a try for 3 games and see the difference yourself.
It didn't fix the entire problem, i would say only 30-35% of it, and that's alot imo.
A back in the day fresh windows reinstall made my game 80% better but that lasts for few hours and sometimes few minutes.
Playing in black and white reduced a substantial amount of input lag
assombrosso
Re: Playing in black and white reduced a substantial amount of input lag
Have you tried playing with the monitor turned off? I bet that eliminates input lag completely.
Changing to black and white may indeed affect electronic lag ever so slightly depending on how the black & white formula is mathematically calculated (e.g. formula on R,G,B, or just only using G as luma), and if gamma is modified during this mode.assombrosso wrote: ↑11 Jan 2022, 06:58As a notorious blurbuster user, i come here to confirm that changing my monitors colour settings to black and white only has helped reduce my input lag, it didn't get red of the problem totally but mouse became abit more lighter, i can control spray, getting headshots is easier, no more screen tearing fps dropping laggy looking things.
Changing contrast ratio is known to move LCD GtG to less GtG-laggy parts of the monitor panel's gamut. So keeping color but changing contrast ratio (raising black levels a little) can sometimes do the same thing while keeping color -- e.g. shadow boost. Dark colors on VA panels are very slow (slow GtG can result in slower human reaction time too), as LCD GtG is sort of part of the "input lag chain", although humans will start to see the photons from LCD pixel transitions early in the curve, the longer the pixel response curve, the more latency to button-to-photons.
I recommend most photodiode lag testers stopwatch at either GtG10% or GtG50% for a more realistic mapping to human reaction time (versus GtG0% or GtG100%) -- different reviewers test differently.
Also, the human vision can react faster to brighter colors, so turning all those reds/blues into whites, can possibly brighten things up somewhat, like a crude method of a shadow boost feature or other image-enhancing setting built into a monitor.
Verdict: Plausible, based on science
assombrosso
assombrosso
Indeed chief, i would suggest people to try this, if they find it too dim and boring, then they should do the other method you suggested, keeping colour but raising blacks in contrast and/or raising whites of bluesChief Blur Buster wrote: ↑14 Jan 2022, 14:47Changing to black and white may indeed affect electronic lag ever so slightly depending on how the black & white formula is mathematically calculated (e.g. formula on R,G,B, or just only using G as luma), and if gamma is modified during this mode.assombrosso wrote: ↑11 Jan 2022, 06:58As a notorious blurbuster user, i come here to confirm that changing my monitors colour settings to black and white only has helped reduce my input lag, it didn't get red of the problem totally but mouse became abit more lighter, i can control spray, getting headshots is easier, no more screen tearing fps dropping laggy looking things.
