zowie xl2546s
Posted: 28 Jan 2022, 02:16
by bajdzik
I only have one problem but I don't think it's the monitor's fault, When I turn on dyac it is most noticeable, the image just rips. Even in the ufo test it is visible and the same in the game :/
https://drive.google.com/file/d/1RkmXIH ... qUGM1/view - please just download the files because through the website it is possible that you will not see anything.
Re: zowie xl2546s
Posted: 04 Feb 2022, 01:44
by Falkentyne
Please check if this happens at 120hz and 100hz also and report back.
Re: zowie xl2546s
Posted: 04 Feb 2022, 03:39
by bajdzik
I checked and the same thing is happening. I replaced everything in the computer, I had 4 3070 graphics cards and the same thing happened on each one, I replaced the processor, nothing improved, even the frames and motherboard and nothing, I tested 4 monitors 240hz and on each of them the same thing, what could be the problem? Monitor drivers installed... pls help me :)
Re: zowie xl2546s
Posted: 04 Feb 2022, 18:18
by Falkentyne
bajdzik wrote: ↑
04 Feb 2022, 03:39
I'm sorry I have no way to help you. I don't even own that monitor to be able to check.
Try running Wagnard's Display Driver Uninstaller in safe mode (DDU), then reinstall Nvidia drivers in regular mode, reboot, and then run ToastyX's "reset-all.exe" in his Custom Resolution Utility zip file, reboot again and then test. If this fails to fix your problem, try a RMA. It's beyond my ability to troubleshoot problems like this, sorry.
