Hi everybody,
I'm looking to buy a 24" FHD 240hz monitor. I'm playing mainly Fortnite (I can get stable 240fps almost everytime).
I never tried 240hz or MBR/strobing backlight but I'd like to try them both. I think MBR is fine if the display doesn't become too dark.
Right now, I have these options:
(I'm from EU so I can't get XG2431 - it will cost 450€...)
203€ - Ozone DSP24
260€ - BenQ ZOWIE XL2546K
213€ - Dell S2522HG
247€ - AOC 24G2ZU
263€ - Acer Predator XB253QGW
273€ - MSI Optix MAG251RX
275€ - Itek ITMF24I281FHD
278€ - Acer Nitro VG252Q
I'm not sure if I'd go for a TN panel due to their downsides, but I added the two I read the most on this forum.
Which of these monitors have MBR and a fast bright panel?
I'm looking at this amazing chart https://docs.google.com/spreadsheets/d/ ... 1179194698
and I think I'm between the AOC and the MSI: which do you suggest? Surely I can buy both and try, but just to be sure...
Thank you for your help!
Which 24 240hz monitor should i buy? + prices
lucapieroo
Re: Which 24 240hz monitor should i buy? + prices
I got an AOC 24G2ZU, I'll try in on wednesday or thursday
Hey, i cant really help you with your monitor but im curious about the Benq 2546K. From which sites do you get this price? For me, the Benq 2546K would be the best options, because of the dyac+ feature for the use in csgo.
lucapieroo
Amazon Warehouse IT - acceptable conditions
I think it’s not available anymore
Do you know something about the availability of the Viewsonic XG 2431 in Eu?
lucapieroo
Today I got my AOC 24G2ZU. It looks pretty but it's my first 240hz
what tests should I run?
Check this post viewtopic.php?f=2&t=8990&sid=35021f6fe7 ... =20#p78301
Just got the Acer Predator xb253qgw, 240hz monitor with rgb/ 280hz (oc). Wow this monitor is amazing and fast. It feelt like the sens incresed abit but it was just the responsiveness and the low input lag. My previous monitor was an Acer Predator xb253qgp (165hz). I noticed the 240hz model is much better in pretty much everything. Better brightness, crisp quality, responsive and low input lag.
