[FIXED] "Menu and Exit to Burn in Off"
Posted: 12 Jun 2014, 04:36
I tried out the MStar upgrader by hooking up the VGA cable, but the ISP tool would only respond with "program file not ready" until I went into the service menu and set “DVI HPD” to “On”. It eventually found the device after that, even though I have no DVI cable hooked up between the upgrader and the monitor, only the VGA cable. Anyway, I managed to upgrade the firmware of my XL2720Z to V2. The ISP tool displayed a "PASS".
The problem is I can't get the monitor out of in-burn mode
"15) If your upgrade went successfully, your monitor will begin flashing solid colors in a burn-in test."
It does this only when the monitor goes into standby. I only noticed the cycling after shutting down windows. While cycling block colours the monitor shows the message "Menu and Exit to Burn Off". When I click on the Menu button at this point all I get is a list of inputs to choose from.. DVI, Dsub, hdmi etc..., but nothing else.
The instructions say: "To turn this off, turn off this mode by press the ENTER button and then RIGHT button on your Z-Series monitor to turn off burn-in mode."
"Enter"? Is that the return button on the S-switch? and by "right button" do you mean the 3rd LED on the XL2720Z?
Also, before the upgrade I could get to the service menu. I can't get into it now.. I suspect this is because the monitor is stuck in in-burn mode.
At least I have full menu functionality while the monitor detects a signal from the PC, but I still can't get to the service menu nor get the monitor out of in-burn mode. Can anyone please help?
