Page 1 of 2
Compare UFOs - Ghosting / Pursuit Camera Motion Test Collection
Posted: 27 Apr 2022, 02:07
by Discorz
EDIT:
- now everyone can add UFOs in new "ADD YOURS" sheet
- changed links
Hello people of Blur Busters,
Pursuit camera test helps visualize what eye-tracking motion blur looks like on a display. Many displays have already been tested by the community and footage can be found scattered over the Internet. Having all the footage in one place would be very helpful. For that reason I've put together this collection out of shots that have been taken over the years. If you've ever wanted to compare one model to the other, this is the right place to do it. Currently there are hundreds of partially covered monitors on the list and number will grow in the future.
TestUFO Ghosting Test / Pursuit Camera Collection | HTML View
TestUFO Motion Test Collection.png (172.53 KiB) Viewed 151631 times
Re: Compare UFOs - Ghosting / Pursuit Camera Motion Test Collection
Posted: 27 Apr 2022, 04:38
by axaro1
This thread 100% deserves to be pinned on top of this subforum, amazing job @Discorz!
Posted: 27 Apr 2022, 07:22
by CortexFPS
Fantastic work, congratulations!
Posted: 29 Apr 2022, 02:32
by Discorz
Glad you guys liked it. Let me know if u have any suggestions for improvement.
Posted: 29 Apr 2022, 17:59
by Falkentyne
Discorz wrote: ↑
29 Apr 2022, 02:32
Thank you for your work.
I honestly can't believe how good the XL2546S and XL2746S look compared to the XL2546K and XL2540K. The XL2546S and XL2746S look very similar, while the K models seem to just have far more aggressive overdrive. No wonder people were complaining about the XL2546S getting suddenly discontinued...everyone who managed to get one here seemed to love it, with the only drawback the double strobing below 100hz (like the XL2746S).
I can find no feedback about the XL2746K however. But the XL2731K looks atrocious.
Of course with Dyac off, the Alienware QD-OLED looks better than anything else on the market. I have no idea why they didn't release a 60-240hz single strobed MBR version of that monitor...
Posted: 02 May 2022, 01:58
by Discorz
Falkentyne wrote: ↑
29 Apr 2022, 17:59
Yes, the S versions are impressive. It has less aggressive overdrive and double image is fainter compare to K, meaning either panel is faster or its tuned better. If panels are the same it's tuning thing. Outside strobing X 25 look nice, VG258QM isn't bad either.
For IPS new panels such as XG249CM, XG2431, PG279QM are looking good.
OLED beats them all it just needs to catch up with brightness so we can utilize bfi properly. But they could of done it. Some people don't mind low brightness bfi.
Posted: 06 May 2022, 13:59
by teo
I saw a monitor go on sale, asked myself "did this one have vrr strobing?" and then thought discorz' spreadsheet might have that information. sure enough, it does contain links for the monitors that offer the feature (even if ufo test isn't ideal for that purpose). I suspect this might be the only list around that can easily identify which monitors support it. just another way this is a great resource!
Posted: 07 May 2022, 10:54
by prod1G
Kudos for establishing and maintaing this Ufo-Database!
Its always my first place to go when finding out about a new monitor.
But i have a suggestion and its to show wich pps setting they where recorded on, if its disclaimed somewhere or is visible in the video.
IMO everything under 1920pps at and above 240hz is too slow to really make out ghosting or overshoot for a real world comparison and can be misleading (and mislead me a bunch) of a givens screen performance.
for example im still searching for a (+)240hz ips that can do a ghosting-less dark top row at high pps.
(my best experience right now is the xv252qf at 300hz with OD normal, where the lower rows are overshoot-free and almost ghosting-free but the top row still shows a long smeary trail, wich i can see in games, too)
Posted: 07 May 2022, 11:37
by Discorz
teo wrote: ↑
06 May 2022, 13:59
That's great. There is also this list of vrr strobing monitors. So far we only don't know how good is MSI's MPRT Sync.
viewtopic.php?f=4&t=8832
Posted: 07 May 2022, 11:57
by Discorz
prod1G wrote: ↑
07 May 2022, 10:54
I thought about marking every link but that would be very time consuming. Only this already is. Other than 960pps shots are marked italic. I'm not a big fan of 960pps either but most of shots online are already at that speed.
As said earlier for IPS PG279QM looks to be most ghost-free right now. For TN Omen X 25, X 27 or maybe even VG258QM. XV252Q F has fastest persistence blur outside strobing mode. Note that ghosting (response times) is separate from persistence blur (refresh rate).
