Hey,
I need some help I hope maybe somebody has the same issue here. Just purchased the XG259CM and when activating FreeSync Premium in my Monitor Settings it tells me Freesync Premium is on but when I go into the Radeon Software to doublecheck if its really FreeSync Premium it tells me that it only is Freesync.
Is Asus advertising their product wrongly or am I just too stupid to understand whats happening. I doublechecked their Website and it says it even on the website that the monitor has Freesync Premium.
Would love some advise.
Thanks
New Asus XG259CM Freesync Premium Problem
- Website.png (39.53 KiB) Viewed 5781 times
- not freesync premium.png (42 KiB) Viewed 5781 times
Re: New Asus XG259CM Freesync Premium Problem
I wouldn't worry about that. It's just naming thing. All you need is it to work properly.
Btw how is the monitor? Some feedback on motion performance or in general?
Pretty good, I would rate it a little better than my Alienware AW2521HF.
Only issue I am having is that the color is pretty terrible without HDR on. (Would have loved to use ELMB Sync but since you cant use ELMB and HDR at the same time I prefered better color over motion blur reduction.)
