Hi,
I never managed to get a clean test on https://www.testufo.com/ , always got "STUTTER WARNING:
Browser stutter detected (1+). Close other apps and tabs."
No others tabs, tried with Chrome and Firefox.. What could be the issue?
Thanks
Stutter warnings
Re: Stutter warnings
Usually it's a browser quirk or power management quirk.
Try Balanced Mode or High Performance Mode.
Can you post a screenshot of www.testufo.com/animation-time-graph -- It's usually a browser frametime spike every second, caused by internal TestUFO processing that normally should take under a millisecond but sometimes takes several milliseconds.
Also try screenshotting www.testufo.com/animation-time-graph#measure=rendering to see TestUFO frametimes .... If you see frametimes suddenly udulate up and down, that's the power management switching behaviour. Spin your mouse arrow on top of the animated TestUFO area (completely within the animation time graph) and it may sometimes stay low frametime and it goes green.
If this is what is happening to you, we may have a fix for this later in 2020. But to help us debug, please PM, email or post screenshots of both graphs.
Hi Chief Blur Buster,
I'm having the same issue, here's the animation time graph screenshot:
I found what's causing it. I use AIDA64 to monitor temperature of my CPU an GPU by placing the corresponding number in tray. Basically it stutters every second, I guess whenever it reads the info from my hardware. If I disable it, there is no stuttering, but also I don't know the temperature.
I also tried HWiNFO, but then it's even worse:
First of all, the stuttering on the 1st screenshot doesn't look that bad. Which effect does it have on my system?
Second, of course ideally I would like to have no stuttering. Is there a monitoring software which doesn't have such downside?
- Screenshot_2.png (137.17 KiB) Viewed 6043 times
- Screenshot_1.png (105.78 KiB) Viewed 6043 times
Temporarily exit all system monitoring software (no Task Manager either!) and see how this graph looks. Monitoring software, apparently sometimes adds stutters, sadly. Ditto for inefficient RGB software, too.
Is there an update on this? I get spikes with Balaned plan, would like to keep balanced as I want my CPU to downclock, just without the spikes.Chief Blur Buster wrote: ↑02 Jan 2020, 02:19Usually it's a browser quirk or power management quirk.
Can you post a screenshot of -- It's usually a browser frametime spike every second, caused by internal TestUFO processing that normally should take under a millisecond but sometimes takes several milliseconds.
Also try screenshotting to see TestUFO frametimes .... If you see frametimes suddenly udulate up and down, that's the power management switching behaviour. Spin your mouse arrow on top of the animated TestUFO area (completely within the animation time graph) and it may sometimes stay low frametime and it goes green.
Most of the spikes come from other software that behaves inefficiently in Balanced Mode, such as RGB software, or even merely running Task Manager. Try quitting these utilities. You may post a screenshot of your spike pattern and I may be able to tell you if it’s a familiar cyclic.Randomizer23 wrote: ↑25 Mar 2024, 19:00Is there an update on this? I get spikes with Balaned plan, would like to keep balanced as I want my CPU to downclock, just without the spikes.
I have no control over a web browser “Canady in Coal Mine” style sensitivity to stutters. Web browsers are very sensitive to background software taking away CPU cycles;
I am using a AORUS GeForce RTX™ 3070 MASTER 8G GPU. I was having stutter issue and a 10 millisecond spike every second, also not v-syncing. My fix was going into task manager and ending "AorusLcdService". No more spikes.
