List of upcoming freesync monitors
Re: List of upcoming freesync monitors
That CHG90 has me drooling The back doesn't look VESA compatible but the chart states wall mount support. I hope the strobing mode is adjustable for brightness
Cougar Conquer 2 | MSI Meg Z390 Godlike | 9900K | NZXT Kraken X72 | 32GB TridentZ RGB 3600MHz | RTX 3090 FTW3 Ultra | Samsung 960 Pro NVMe M.2 SSD RAID-0 | Corsair AX860 | 3DMark Port Royal - 14204 | Windows 10 Pro 64-bit | Triple 32" Samsung CHG70 | Samsung CHG90 Super-Ultrawide Auxiliary
I noted these words in the marketing text: "The CHG90 also boasts a rapid 1ms response time, 144hz screen refresh rate, and advanced, four-channel scanning technology to deter motion blur throughout the entire screen".
What does that in bold mean?
Also, I'm wondering about the following:
1. How tall is it? Same height as a 27"?
2. Can the Hz be set in 1Hz steps, or are there only "set" Hz settings, i.e. 60, 75, 85, 100, 120, 144? That is, when not using Freesync obviously (I have an nVidia 1080 Ti).
It's about the same height as a 27" 16:9. The height of a 49" 32:9 is 13.3". The height of a 27" 16:9 is 13.2". So basically it's the same, except with more space on each side.whitestar wrote:1. How tall is it? Same height as a 27"?
I don't know if the curvature plays into it though. The height might be wrong depending on how they measure the diagonal (straight or curved diagonal.)
This is Samsung proprietary blur reduction capability -- someone will have to test strobing with custom refresh rates to see if it works.whitestar wrote:2. Can the Hz be set in 1Hz steps, or are there only "set" Hz settings, i.e. 60, 75, 85, 100, 120, 144? That is, when not using Freesync obviously (I have an nVidia 1080 Ti).
