What?
Fix for input lag
Re: Fix for input lag
This is getting more and more insane
What are some of the other tweaks that you have applied that are working?Mugabi wrote: ↑03 Apr 2024, 13:55I think with this and other tweeks plus breathing technique that i have developed. I have managed to get the smoothest gameplay i have ever gotten past 10 years that is consistent now for over 2-3 weeks. Before all fixes including this give me temporary relief of symptoms then all go to shits. Now its lagless and consistent. Iam hitting stupid randmo shots from end of the map consistently and ppl think im hacking lol. I hope i can get it to be similar to a fresh windows reinstall all the time, with luck faith i think we can ship this. Ill make a video soon showcasing everything.
This one (deleting EDID) works wonders for me, especially because I just put my PC to sleep, and never shutdown, so the effect is everlasting (didn't apply the PSTools method, just so I can do it manually so it gets ingrained into me for future Windows Installations).
The recoil in CS2 is so much better, and as you mention, I hit incredible shots. Also, what I would recommend to everyone here is to try a program called Raw Accel.
There's tons of guides, but 2 main things you should focus on are: X/Y Ratio (I set mine to 1.15;default 1) which further reduces the "starting" recoil, permanently, in all games. Also, the setting called rotation, as I hold my mouse naturally a bit towards my body and not in a straight line, so this makes the sensor appear as the mouse was completely straight. I personally use -2.75 (default 0) and do NOTE both of these settings are personal and even small change are making a difference, so definitely try them in increments.
what brightness trick?n1zoo wrote: ↑02 Apr 2024, 15:14ok so I tried brightness trick and everything ccfan said. it's much better to play, the mouse itself is not very sharp, but the game is much more enjoyable, the hitreg is better too, less desync. compared to the game before the "fix", things are definitely better, I wonder how long it will last.
