Yeah xD, I mean only the first psu literally made an explosion, it was like a flashbang xD, then it turned off my pc and didnt turn on again, so I had to change psu, then the second one died over time, and then I got the new pc with a different psu and it didnt die but when I was opening a game my pc shuts down instantly under "pressure", so I had to buy a new one 2 weeks ago and I dont have more problems, the psus are good btw, is not like im buying shitty psus, now im on my new house so I dont think my psu its gonna die again, I think it was because of a bad electricity, I remember when I plugged things into the power in that house, sparks of light would come out, but anyways if that fucked my components why it doesnt show any issues in programs when I test ram, gpu etc? I dont know everything looks fine, but I have input lag and I cant proof it, thats the worst part, and btw I changed the battery 1 day ago, it feels the same no difference at allimprecise wrote: ↑17 Dec 2022, 18:54You had 3 PSUs explode? I wouldn't trust anything from that computer any longer. GPU and/or RAM is likely messed up. Are you able to swap these out for known good components and test?Smokq wrote: ↑15 Dec 2022, 23:54I would send a pic of it, but I tried so many versions of LAN drivers, I tried with default settings and also with the settings in the screenshot you have sent, I dont think its because of the settings, it has to be drivers, my motherboard or my network card, but its so weird because I have the same issue with 2 different motherboards "msi x470 gaming plus" and "Asus prime b450-plus" I know both of them are not the best for gaming, but should I have this issues with desync, and mouse feeling? I noticed that my mouse issue gets fixed while using mobile data but it only works when the cable of my phone is not connected to my motherboard usb, because when it is plugged in to my motherboard the lag is still there, but when is plugged to the frontal usbs everything its fine, not 0 input but 100% better, I guess is not perfect because I cant ask much from playing with mobile data xd, so I dont know I tried everything, I dont know what more I can try, and I dont have money for a new motherboard, I dont even know if that would fix my issue, I just know that everything started in my old house with that shit electricity that made 3 of my psus explode xdd, im still woried that the gpu/rams or my battery bios is fucked from that explosion in my old pc (I use that 3 components on my new pc)imprecise wrote: ↑12 Dec 2022, 21:35Can you share a screenshot of your network settings?
example:
download/file.php?id=2990
The battery is probably fine but it would be really cheap to replace.
And nope, im not able to change my gpu or my rams, thats a lot of money and I dont have that much, im gonna buy a new motherboard next month tho, I will buy this one: "Asus ROG STRIX B550-F GAMING"
I dont even know if this will fix anything, thats why im so sad, because I dont want to waste money on random things, but what can I do man ):
