Is this input lag? (Video)
blackmagic
Re: Is this input lag? (Video)
Post by blackmagic » 15 Mar 2023, 05:09
best way how to identify and see if input lag or not input lag...
https://www.youtube.com/watch?v=-MM0Z_jCrGo
i always use this method by myself.
because i don't trust my eyes.
and very important...
you only just need to ask the right question...in your case: "Is this input lag ?"
and the pendulum gonna tell you.
good luck.
mago
Post by mago » 15 Mar 2023, 05:59
mb with 120 / 240 fps camera it will show more clearly
Ⓢк𝕀lŁ เ𝓢 ᵗⒺм𝕡σr𝐀𝐑Ⓨ, lά𝔾 I𝐬 F𝔬ʳ𝔢𝓿ᗴ𝔯
blackmagic
Post by blackmagic » 15 Mar 2023, 06:00
mago wrote:
15 Mar 2023, 05:59
yes maybe...
or maybe not... :lol:
but i think and believe my method is better than any high fps camera...in this special case...
Post by RealNC » 15 Mar 2023, 09:47
mago wrote:
14 Mar 2023, 15:49
why there should be game animation latency if he run at 400fps ?
Animation is based on real time, not frame rate. If it was tied to frame rate, games would run at twice the speed when doubling the frame rate.
babooz99 wrote:
14 Mar 2023, 21:56
Here's with ESC key
Where?
Also, why not try something simpler instead? Like simply zooming in your browser to very high value, and then simply type something in the post editor and see if there's any delay between you pressing a key and the character showing up in the editor.
imprecise
Post by imprecise » 15 Mar 2023, 14:44
Sirito wrote: What the slow movement has to do with input lag? isn't input lag the time it takes for the action to happen?
The slow movement could just be perception based, like he pressed move so much earlier that the player acceleration should have kicked in by now. Or, the problem is affecting both the game's reaction to input and the acceleration speed. It does kind of look like both to me, but it's difficult to say for sure.
Sirito
Post by Sirito » 15 Mar 2023, 15:31
imprecise wrote:
15 Mar 2023, 14:44
I understand, but how the problem is affecting the acceleration speed? this is something outside the input lag circle right?
imprecise
Post by imprecise » 15 Mar 2023, 15:39
Sirito wrote:
15 Mar 2023, 15:31
Inputs flow into the system, and outputs come out. There can be delay in both. I hope this helps.
babooz99
Post by babooz99 » 15 Mar 2023, 17:08
RealNC wrote:
15 Mar 2023, 09:47
mago wrote:
14 Mar 2023, 15:49
babooz99 wrote:
14 Mar 2023, 21:56
Here's with ESC key
Where?
here
https://streamable.com/or4z4q
i dont know why my posts keep having to be approved by a moderator thats really annoying
Post by jorimt » 15 Mar 2023, 17:13
babooz99 wrote:
15 Mar 2023, 17:08
The first handful of posts and post edits are manually moderated for new users. After that, manual moderation is lifted.
You know what's even more annoying? Us moderators having to manually remove dozens of new spam/bot users and posts a day. If we didn't have manual moderation in place, they would bury the real posts in no time. Necessary evil, currently.
Post by jorimt » 15 Mar 2023, 17:22
babooz99 wrote:
15 Mar 2023, 17:08
here
Seems pretty instantaneous to me (factoring in any debounce latency from your particular keyboard and monitor processing latency), even at 1/4 playback speed.
To give you an idea, while I didn't use strafe, I used look in CS:GO mapped to the mouse click in my G-SYNC 101 article several years back to test input latency with a 1000 FPS camera and got 14-16ms on average from click-to-display at 240Hz:
https://blurbusters.com/gsync/gsync101- ... ettings/9/
Going by your ESC latency, it appears CS:GO strafe probably has some intentionally built-in animation delay, which is one of the reasons I think I decided not to use it for testing.
